Hi all, discovered I have two oil leaks coming from the front two boxes on the E64. Right a the front of the engine block. Does anyone know if these can be corrected/repaired without taking the heads off or not. Any advice would be appreciated.
Morning Paul
Check the Upper timing case gaskets they are steel and rarely give problems but worth a check the solenoid valves in them which have "O" ring seals (more likely) Next Rocker cover gaskets these are a common culprit, good clean up then run the engine and look carefully for signs
Good Luck
