Does anyone know where to jack up my 330xi with a hydraulic jack and where to place the jack stands?
Morning Lou
Your hand book for the car will indicate where the recommended jacking points are. If you are using a trolley Jack there is a reinforced lifting point at the front of the the front subframe, or under the Diff at the rear then place axel stands under the cars jacking points. It goes without saying the car should be on a solid level base with wheel not being lifted chocked to prevent any movement.
