I have a BMW 2002 SERIES 1976
Does anyone know where I could get a clutch slave cylinder kit or clutch slave.. The clutch slave cylinders seems to be out of stock on the internet..
Morning David
If you aren't aware check www.realoem.com classic section enter the last 7 digits of your Vin then check the section you need (Clutch) Double click part numbers and you should see a list of Part numbers and any alternatives that were used. You will also see dimensional information.
An internet search using the alternate part numbers may help source something (he says hopefully) I guess you have already tried BMW UK Classic Customer support
If none of that works an Engineering shop may be able to re-bore the cylinders you have or may be remanufacture them
Good Luck
