F31 has knocking noise o/s/f and can be felt on steering column. Only occurs on longer journeys and noticeable at very low speeds forward and reverse. Intermittent so hard to get diagnosed
Morning Rob
From your description the knock can be heard/felt in the steering, jack up the car and spin the wheel can it be felt/heard.
I would expect a noise/knock to indicate possible damage to (a) Wheel and Tyre (b) Wheel Bearing issue (c) Brake Disc issue (d) something loose
Without seeing feeling hearing the noise it is impossible for us to diagnose your issue only give clues of where to look
Hope this helps
Thanks for your reply Dave, most appreciated and I’ll try and check as you suggest. If anyone else has had a similar problem it would be helpful to hear the outcome and if the issue was resolved
Rob
      Trailer Hitch
      Mobile charging tray not working
      2006 BMW X5 E53d
      2006 BMW X5 E53d
    5. 2
      New member
    • Appash29 went up a rank
    • Curious earned a badge
    • I Love Gravy earned a badge
    • Baker25X3 earned a badge
    • OzTex earned a badge
