Have a 2010 X3 but the Bluetooth option is not activated. Can it be done?
Morning Luis
You can check by using a BMW Vin decoder website put in your Vin number and it will bring up the build sheet for your car. If the car is Bluetooth equipped you will find either SA633 or SA644 codes, if they are there then the car is Bluetooth equipped. Two things will stop it working (1) The Bluetooth memory is full 4 phones I think. (2) the Telematics unit in the Boot/Trunk left side is not working
If your not seeing a Bluetooth function then it will be the Telematics unit and its antenna. First check the boot area left side if the telematic unit is there unplug it and get the part number from it then use Google to source a replacement
If your car was not Bluetooth equipped check the left boot are for a connector taped up in the loom in that area if it is there you may just need the parts. Then if you want it to be OEM use www.realoem.com to get the part numbers and source the equipment, it should be pretty much plug and play.
The alternative is an after market Bluetooth kit
