Hello all
Does anyone know which is the cable that is connected to the thermostat heater element, the plug that is on the side of the thermostat housing. I was working in the car and removed the plug from the housing a few months ago and now I do not remember which of the two plugs, there are two identical plugs on flying leads close to each other, is the one that I should connect to the heater element.
Many thanks
Morning Dimitris
Just checked my wiring diagram in ISTA and it doesn't cover E38 models so not much help at the moment but I will dig
      BMW E70 Air Suspension
    2. 4
      Diesel Engine Running Rough
      X5 electric range
      suspension / service
    • paul001 earned a badge
    • GermB earned a badge
    • Appash29 earned a badge
    • FuriiousTV earned a badge
