 Hi my Battery is flat, my fob does not work.
Removed caps at the side of the door handles, no emergency keyholes/locks present.
I do have the fob keys, but no lock to put them in.
BMW 420d 2014
Any ideas how to get in the car?
Any help appreciated
Thank you
Afternoon Frankolinno
I would start at the Boot/Trunk look above the number plate for a Key hole, you should have a key blade as part of the Fob
Find the Key hole open the Boot/Trunk and you have access to the Battery. If charging the battery remove it from the car to charge it. There should also be an emergency key hole on the underside of the drivers door
Good Luck
