brake balance
HI all, my 650i seems to now be pulling to the right under braking. Bit of a new phenomena this. Is there a recommendation on checking braking balance or is this likely to vary over time. I am just trying to better appreciate the likely cause and what it is I am asking for with regards to work and measurement.
Thanks.
Afternoon Paul
Sticking calliper would be my guess, or pads binding in the holding pins. Did find a rear parking brake sticking on a friends Volvo car ran straight on the road but touch the brakes and it pulled to the left
Any heat on any wheel centre ?
Thanks Dave, it is intermittent to be fair which could be explained by the caliper observation. Ill give them an overhaul in the spring and see if that changes anything and report back.
    2. 5
    3. 5
    4. 5
      Failed turbo
    5. 12
      Power Message
    • jon green earned a badge
    • bill gall earned a badge
    • kor earned a badge
    • Damion earned a badge
      Reacting Well
