Is there a way to get the original window sticker?
Engine cut-out on idle.
Tapping
Hi Daniel Welcome to the Forum Your tapping noise could be a number of things from a sticking hydraulic lifter to a failing chain tensioner. What is the service history ? Extended service intervals can cause issues get the Chain tensioner checked/changed would be a starting point Dave -
8
- contact failure
(and 2 more)
Tapping
Hi Allan Welcome to the Forum The fact you can hear a hiss sounds like either an air leak (inlet manifold) or a vacuum leak Both will upset running a bit more information what engine diesel or petrol would help Dave
