Angel eye install…. Stupid glue!
My new E64 650i
I’m not sure what you mean. Are you saying you get engine braking in non-sport mode? -
2019 X1 stereo system upgrade
Thank you so much, that's a massive help -
iPhone 17 with iOS 26 issue
Morning Darren Welcome to the Forum I take it your previous phone was iphone which it seemed worked OK ? If so as nothing else but the phone has changed this is more a question for Apple than BMW Make sure all previous registrations are cleared on the car then re-register your phone if that doesn't work ask one of the Apple Forums Sorry best I can think of for an Old Android Bloke Dave -
I’ve recently change to iphone 17 with iOS 26, since changing, every time I use the voice activation button on the steering wheel to make a call or send a message, it seems to call MY Number. Any help or support or fix would be much appreciated -
Hi Rick If you look at www.realoem.com put the last 7 digits of your Vin into the search box it will bring up your Model Then search the Audio section you will find small exploded drawings showing where speakers are for each system. Get the part numbers for the HK stuff then search the internet for the best prices and supply. You could get all the HK stuff and AMP and swap them yourself make sure the under seat speakers are there and working then add a sub if you need it May not be as costly as you think Dave
