Morning Joe
When was the car last serviced ? Did they change drive belts ? At higher mileages I would change change Belts and Tensioners, plus while your in there with no belt in the way check the alternator water pump and aircon pump pulleys
Certainly sounds like a pulley
Morning Dave,
Serviced last in February. Had oil, coolant and brake fluid change. As of the belts and pulleys there's nothing in service history. The auxiliary belt does show signs of slight cracking, I've bought a new belt and water pump to do the job but wanted to try and source the noise so I can fix that while the car is in bits. Any suggestions on what pulleys I need? Wanted to try and replace only the worn ones but not a clue how many/which ones need changing.
Cheers,
Joe
Hi Joe
Take a look at www.realoem.com if memory serves there is a deflection pulley and a tension pulley. The deflection pulley I think is plastic so could well be your culprit
Try a squirt of WD40 on the centre of each pulley (do it 1 at a time) if it stops the noise you know which it is
  • 6 months later...
Been a while, forgot to update sorry. Turned out to be the belt tensioner pulley at fault, bearing was goosed. Hope this helps some people.
  • Thanks 1
Hi, my e87 118d msport making the exact same noise, was this an easy repair?? I'm quite handy with a spanner. . Cheers.
Morning Nick
Check www.realoem.com put the last 7 Digits of your Vin in the search box then search the engine section to find where it is
Then take a look at the car to see what is in the way (how much stuff needs removing) then if your happy crack on. Use the part number from realoem to get the parts needed
Good luck
Fairly easy for me with limited knowledge. Took and hour or 2 at most. Changed the belt whilst there, if you do make sure it's the right length as there are a few types depending on accessories such as a/c. Once the belt was off you can spin each pulley and locate the bad one. In my case it was one of the tensioners.
  • 6 months later...
Great advice gents, got a similar type of noise, literally started today, definite cyclic in nature so linked to the belt and pulleys and will try the WD40 first to see if I can isolate the cause of it before moving on.
      BMW X1 valve cover gasket replacement
      650i VANOS failure
      650i VANOS failure
    5. 2
      2017 430d LED headlight beam adjustment for continental.
    • GermB earned a badge
    • tomy987 earned a badge
    • Brummieboy77 earned a badge
    • Julian Pasiut went up a rank
    • tricz earned a badge
