Question
X1 gearbox service
X1 gearbox service
Hi Dave, thanks for the reply. I've only had the car for 2 weeks and so far it's running good, i could probably diy-it but I've not done it before so the missus won't let me🤣( it's her car) . Local BMW dealer quote me 830£ for gearbox service and 550£ for transfer box/boxes service. Safe to say I told them I'll sleep on it for a bit😁 -
im having this issue where during driving the car changes to neutral , has happend twice now. car is x3 f25 20d -
Inherited an R56? 2009 ONE
I’m guessing this one hasn’t been serviced since it was born! … I took the filter box apart and it needs replacing. Someone has tried to fix it before, but it’s beyond alive now! Haha. the bootlid needs either pushing out or replacing, as does the rear bumper after it got into a fight with a bus… and a rear light… apart from that, it seems well. 😂
