Hi replaced my rear driverside caliper I clamped the flexi pipe going to the caliper to caliper off replaced new caliper bled it now I can't get a pedal can't understand it no air in the pipe pure fluid coming out help plz.
Scot
Morning Scott
First did you check the reservoir before and during the work? If not it may have dropped allowing air in. Also many makes of car need the ABS unit to be cycled when bleeding the brakes (normally done using the Diagnostic program)
What method did you use to bleed the brakes ?
Hi greydog.
I took lid of resivour done shoes pads and discs  I clamped the flexi pipe rear drivers side took off old caliper replaced new caliper took of clamp got a friend to go in the car checked fluid level all ok opened nipple said down closed nipple done this 4 times pedal crap ok pump up the pressure 3x opened nipple still crap pressure bled it today still crap. Hellllp
Engine running when pumping the pedal ? When pumping the pedal do you get pressure ?
If the reservoir levels  didn't drop and allow air in then it must be ABS needs recycling. There is an old trick that may help you pump the pedal to get pressure there and hold it cut a piece of wood that will fit between the pedal and the seat frame, then use the seat adjustment to hold the pressure on the pedal and leave it overnight. Leaving the brakes under pressure can sometimes clear non return valve issues so worth a try if it improves things repeat.
Also check the non return valve at the servo if it is faulty it will not help.
Cheers dave it is that aide I clamped the flexi and started car pedal was fine I'm gonna clamp the 4 of them incase fluid did get that low and take one of ar a time and take it from there doing ur trick night work I will bring my snap on diagnostic with me tomorrow as well see if it will recycle the pump as well
Depending on the Snapon tool you have I thought there was an ABS cycle function on them?
Now I feel a bit stupid. So I decided to bleed rear passenger side knowing fine well it would make no difference. Took the wheel off and immediately found the problem nipple on passenger side was at the top yes u have guessed it wrong caliper they gave me for driverside so it would of never of bled in a million years. So back to motor factors turned out the box was already open when I got it so it was the right box but wrong caliper inside someone had changed it somewhere down the line and handed it back with the passengers side caliper in the driverside box. My issue is why I never noticed it straight away numpty. Anyway thx to everyone who gave advice much appreciated.
Scot the sniper
Well at one time or another we have all been there, that Dohhh moment
At least now your sorted
Have a great weekend
      Inherited an R56? 2009 ONE
      1996 750i
      X1 gearbox service
    • Richcj earned a badge
    • victormeldrew earned a badge
    • Von earned a badge
    • DDMORE earned a badge
