Error codes fog lights
Birdie
Hello can anyone help me i wanna change my fog light bulbs over to bright white, where do i get error free bulbs from please that i can just swap over... And is the replacement easy to do, cheers
Birdie
Morning Steve
I take it you want to change to LED replacements, 4500k to 6000k would give the same look as the headlamps?
I believe the LED bulb type is H11. Space is tight so check they fit if you can before buying, also check if they are sold as "Canbus Error free" if not you will need inline resistors (one for each lamp) to avoid bulb failure errors popping up.
A google search should find you a supplier
      Resonator assembly clip
      04 525d
      2e47 & 2e41
      Coolant leak
    5. 2
      Coolant leak
    • Droffilc earned a badge
    • Robbawdie earned a badge
    • Kev Miller earned a badge
    • Jeags earned a badge
