10.25” screen android unit BMW X3 F25 2010>2018
Driver door stuck locked
After many months of messing with door i decided to try, again, the key in the door after about 10 tries THE DOOR OPENED!!! So I can finally get door panel off to access and replace the actuator. Thank you to everyone that responded and tried to help me. And to Greydog...I found the lever you were talking about. -
Reverse camera
Hi Meggy. You can install one to the x6 if you have a compatable head unit. If not, you can get aftermarket stereo systems which have camera inputs I’m not familiar with the 6 series, but it may be possible that the wiring look is already installed and just needs a camera fitting and enabled. stu -
z3
Hello Michelle. someone is selling a pair on eBay… https://ebay.us/m/YoEja0 is this what you are looking for? Stu -
5
suspension / service
Hi Jerry You say Shocks, arms, springs OK what about Anti Roll Bar bushes and links ? Have you checked the Sub Frame mounts ? Also worth checking the engine mounts ? Is the Engine reinforcement plate in place and tight. As you feel it in the footwell my best guess is Anti Roll Bar bushes Dave
