Have checked fuses all ok but no pos feed down to washer motor
is this likely to be the switch
it will very intermittently operate if switch is left on
Hi Jim
The switch should be easy enough to check with a multi meter, same with the loom to the washer motor. Check the earth connections carefully BMW use a lot of common earth points which are often at the bottom of the problems.
      "Battery Management" message
      3 series for sale
      3 series for sale
      DPF Cleaning fluid
    5. 3
      3 series for sale
    • Alan Sirota earned a badge
    • Mark Fielding earned a badge
    • ZedJay earned a badge
    • Mick W earned a badge
