  1. Tap the 3-dot menu (โ‹ฎ) in the top-right corner of the browser.
Water in passenger foot well?
Water in passenger foot well of my 2014 X1 Xdrive 20D se BMW, suspect blocked AC exit tube..where does it exit?
Don't know.......but I suspect you've got blocked drain channels under the bonnet.ย
At the rear corner on both sides there are water drain holes covered in a plastic grate. These get blocked very easily and water can then access the interior.ย
I'd check these out first it's a two minute job.ย
Hope it helps.ย
Upt'North.ย
ย
Are you a Honda Motorcyclist by any chance........ย
5 hours ago, Greydog said:
Hi John
Don't dismiss water entering through the passenger door check the membrane in the door is undamaged and sealed, plus silly one is/was the passenger window fully closed?
Hi Dave
Thanks for the information.
I am confident that the water is not entering through passenger door membrane or the door seal as it only happens when the Air Conditioning unit is on.
Hope it helps.ย
Upt'North.ย
ย
Hi Upt'North
These were the first areas i checked but they were clear.
ย
Yes i own two cx500ec Eurosports....one in bits and one on which i completedย a nut and bolt restoration in 1990 and which has sat unused in my garage since 2007.
If it only happens when the AC is on I would be checking the integrity of the Condensation drains that normally give the little puddle of water under your car when idling on hot days.
Take a look at www.realoem.com search your model and look at the exploded drawings for the location of any drain tubes. Remember getting to them behind the dash may need the help of a contortionist.ย
Hi Daveย
Thanks for the information it was extremely useful and has sorted my "Where does it exit" issue.
I looked at the www.realoem.com site as you suggested and found that there are Left and Right handย drain tubes (this now means i can easily find the exit point of the unblocked r/h drain tube by running the a/c unit with the car idling on my drive andย looking for the tell tale puddle beneathย the car and using someย logic i reckon the exit point of the blocked l/h drain will mirror the r/h one on the l/h side of the car.
What i'm hoping is that the Left Drain hose is blocked at the point where it exits the bottom of the car and when i find it will poke a piece of flexible wire up it to clear the blockage. If this does not work then i will have to start stripping the dash until i find the leaking/loose pipe (which on the exploded drawing on www.realoem.com is buried somewhere behind the dash) and repair/replace it.ย
PS:- Do you know of any pics/photos i can access which detailsย how to strip the dash without damaging any of the plastic parts?ย
Thanks again for your help.
John
Morning John
A couple of other sites I use www.newtis.info this is a BMW Technical Information site same info as used by BMW Dealers. It is their repair and service manual with luck descriptions and how too's will be there.
If not look at www.pelicanparts.com this one is an American site (so steering wheel on the wrong side) but full of very good how too's with photographsย
I have not heard of your problem before but I would look for Heater AC sections
Quote
ย
ย
10 hours ago, Greydog said:
Morning John
ย
Evening Dave
Thanks again for the useful information; I have checked out the newtis site and based on the information/special tools they detail i hope i don't have to start stripping the Dash to get at the A/C unit pipework.
First job thisย coming weekend is to identify where the exit point of the L/H drain hose is under the car and hope it is blocked and that i can unblockย it easily by using a flexible wire; if not i think this problem will have to be sorted out by my local garage.
Thanks
John
As the drain is normally a rubber pipe I am thinking that an over enthusiastic valeter has possibly dislodged or folded the drain with a hoover nozzle. With luck maybe you can get your hand in there and sort it. Or if you have hands like mine a bendy 10 year old Grandson works well in tight spots
Good evening Dave
I have 2 bendy grandsons i could call on to help me (6 & 11 years old) and i'm sure that if i flash the cash they will help me with the tight spots..........l.o.l.
Here's hoping it's an easy fix........will let you know how i get on.
Kind regards
John
On 9/6/2019 at 6:57 AM, Greydog said:
2 sizes, your specialist tool kit overflowsย ๐Ÿ˜ย
I'm confident my "Water in Foot Well" problem is now sorted,ย and detail below what i did.
I started the car, set the A/C to 16 Deg, switched it on thenย set the fan toย maximum speed and left the car to tick over.ย After about half an hour i had a small puddle of water on the floor beneath the car which then indicated where the drain point for the A/C condensate was.
I then jacked the front of the car, crawled under and found the outletย drainย on the R/H side wall of the gearbox/prop shaft tunnel next to the gearbox and as you predicted itย was made of rubber (i expected to find two drains but on my car i only hadย one). Small drips of water were emerging and dripping on the floor/my body every 2 seconds, but when i reached up and squeezed the rubberย i was immediately drenched in about 12 plus litres of water.....that was myย second shower of theย day!
When i inspected the outlet ofย the drain found that the rubber flapย (the shape of a birds beak) which was supposed to stop dirt entering and allow water to escapeย had not been formed properly ie:- only about a quarter of itย was slit/free of the rest of the rubber of the drainย and allowingย the water to escape. I then proceeded to release the rest of the flap.
I have just come back from a 30 mile driveย with the A/C on 16 Deg and max fan speed and thankfully no water has dripped onto the passenger foot well.....Job Done....until the next one?
ย
Thanks again Dave for your support and help.
ย
John
Well done John. Take a bar of soap out with you next time. Good info, thanks.ย
Upt'North.ย
9 hours ago, Greydog said:
Whoop Whoop that's the sort of fix I love no delving into your wallet.๐Ÿ‘
That is a huge amount of water that had built up no wonder the carpet was wet.
Sorry, i should have typed 12 plus Millilitres and not Litres of water (i,m old school and am more comfortable dealing with pints and gallons); and that had built up in the half hour the car had been idling with the A/C running flat out.
John
Upt'North.ย
Hi Upt'North
Yes i will and also remove all my clothes.......l.o.l.
John
  2. Tap Permissions โ†’ Notifications.
