On my 2006 X5 Le Mans the passenger mirror used to tilt down when the car was put into reverse now since setting the driver's seat position on the memory function it does not move when I put it in reverse does the seat memory override the reversing mirror function
Morning Steve
The tilt on reverse function is controlled from the mirror/window control panel on the drivers door. I would guess you have sat in the drivers seat and adjusted the mirrors and seat? When adjusting the mirrors you have left the selector switch set to the drivers door mirror side, slide it back to the passenger side and it should tilt on reverse again.
  • Thanks 1
On 8/6/2019 at 7:23 AM, Greydog said:
Morning Steve
That worked perfectly. Thanks so much
      suspension / service
      X1 gone
      X1 gone
    5. 2
      X1 gone
    • stevea earned a badge
    • hobofast earned a badge
    • paul001 earned a badge
    • GermB earned a badge
    • Appash29 earned a badge
