New Member, Old 540
Water Leaking Into Rear Footwell
ah, obviously the foot spa optional extra wasn't installed correctly. Did you find the cause? Water is a sod, I had a slight leak into my wheel well (about an egg cup full). Tried it out and kept an eye on it, it never has so far come back and I never did find the cause. My current working theroy is that it may have been when BMW wet vacced the carpet before sale. I know it sound rather rudimentary but you could try taping paper towel around the footwell above the waterline, that would at least give you an idea of where it's coming from if it's coming from the sides. If its holding that much water then I would'nt have thought it would be leaking from underneath as surely it would drain away. Is the carpet in the front dry? Door seal on correctly? My old golf, I had slightly moved the door seal and it was suprising how much water did get through. Do you have any drain holes somewhere near the boot hinge? -
2008 135i convertible steering column tilt
Morning Larry All the under tray covers from memory but the job was achieved from under the dash. I took out the drivers seat to get more room (disconnect the battery) but if your young and bendy you may be able to get way without removing the seat 🤣 Check the internet for any how too video's 1 2 3 4 series are all very similar. One of the best bits of modern phones is being able to take pictures of how things fit and where they go that will help when putting stuff back If you know anyone with a copy of INPA/ISTA (BMW Diagnostics) it includes TIS (technical Information) and WIS (Workshop Information) which obviously helps knowing how a dealer would go about it Dave Just found this picture shows how the spring fits (this from a friends pic collection Hope it helps -
97' IL for sale
I have a 97 IL available for sale. 160000M. Needs some work such as heater hose. Disk changer is inop. Most pixels are out. Thought I would post here for guys who might be interested. -
Dave, Thanks so much. I see the spring in the parts diagram. Do you know if any part of the dash had to be removed? Thanks again Larry -
8
suspension / service
morning suspension on hold as I've had lurgy , intercooler has arrived so attacking it Saturday as long as amy (rain storm) doesn't show her face , sorry when you rev car n/s pipe expands but air sounds loud from n/s front. thanks for all info and will check on realoem cheers j
