Abs @ Engine Management @ Lights On
Inherited an R56? 2009 ONE
I’m guessing this one hasn’t been serviced since it was born! … I took the filter box apart and it needs replacing. Someone has tried to fix it before, but it’s beyond alive now! Haha. the bootlid needs either pushing out or replacing, as does the rear bumper after it got into a fight with a bus… and a rear light… apart from that, it seems well. 😂 -
Great little cars Stu A neighbour has one and she loves it they do need a good annual service though, seen several that were unreliable due to not being used much and waiting for the service indicator to tell them it needed service? One was 5 years between services? You will also need a good code reader Dave- 1
1996 750i
Following further conversation with the owner, he has corrected me to say its a September 1995 model. 5.4ltr V12 SWB. Apparently there were very limited numbers of this model in right hand drive. Any interest of advice please let me know.
