Front windscreen washers
All sorted now, hubby figured out that the pumps were around the wrong way. 🤣 He insists that it wasn't him. Thank you so much for your help. -
- private reg
(and 7 more)
- private reg
(and 7 more)
9
- eu spec
- contact failure
(and 2 more)
Engine cut-out on idle.
I agree with Greydog. have a look around the MAF sensor. A split between this and the engine block will give erratic air mixture. also, check the battery voltage … my x5 sometimes starts rough idling and revving when it’s a bit low and throws a throttle position sensor fault at me.
