Bought Bigger Wheels With Non Run Flats Now Light Comes On
Has anyone put an Airtag or Tile on their key fob? Seeing some mixed comments elsewhere about them causing some type of interference issue and draining the FOB battery. -
14
Thanks for the feedback Dave, really helpful stuff. I bet your friends and family are pleased you are sorted when it comes to puncture repair kits to keep them on the road. I like the sound of a puncture plug kit & tyre weld for screws and suchlike issues to help stay moving. Sidewall rupture is a flatbed for now, but I'm definitely going with non RFT in 17 months for the next M40d which I really enjoy driving. Ironically, we were in Arundel, W.Sussex when I got the recent pot hole blow out, so know exactly what you mean, I could not believe the state of the roads in the south of England to be honest, it was like wacky races avoiding pot holes on any main roads. We live in sunny N. Yorkshire and don't suffer from quite so many holes in the roads. Thank you for the information, but interestingly, I have already logged a claim for vehicle damage (tyre) with W. Sussex CC when I got home, their website says it can take 24 weeks before they even look at it... I'll wait and plan for the fight. Cheers Jon- 1
14
Morning Jon The main reason I moved away from run flats with the X5 E70 was tyre choice, with my E53 X5 I had plenty of practice. I learned that the recommended Star marked tyres were (a) not necessarily easy to get (often on back order) (b) They were also very premium priced (as you know) I started using Bridgestone and Hankook and found that they were as well matched in a staggered set as the Star marked tyres so no transmission damage. I brought the E70 to cut the miles going onto the other X5 and quickly moved it onto Hankook non run flats a set of 4 285x40x20 Front and 315x35x20 rear was just under £800. In my breakdown kit I have as said a small compressor a can of tyre weld (or similar) and a tyre plug set. I have used it a couple of times a friend of my wife has a Volvo V60 on run flats she ran over a screw one of the plugs fixed it and stayed fixed until she needed tyres. My son inlaw suffered pot hole damage to his 330e when visiting us, a can of Tyre weld got him from Sussex back to the West Midlands where they live. When he went to the tyre shop they said "shouldn't use that stuff mate we cant repair tyres that have it in" well with 2 splits in the inner side wall it was a new tyre anyway but at least he could drive 190 miles and not be stuck overnight waiting for somewhere to open. If there is a puddle I slow right down or go around if I can because in sunny Sussex it will be a Pot Hole I would go with a repair/limp kit like mine and fingers crossed the roads on the continent are in better nick than ours As an aside our son inlaw started a claim against the county council it took ages to get a resolution they wanted to know how many miles the tyre had covered ? then how old was it then said as it was a used item they couldn't offer full value !!!! An invitation to appear on Rogue Traders finally got through Dave -
Clicking noise when disengaging clutch either when pulling off or changing gear, happens more in lower gears but can still happen in higher gears. if sat with engine running, in gear and handbrake on, and slowly release the clutch until it’s hitting point I will make the clicking noise aswell any ideas as to if this is serious or just a common bmw noise?
