Replacing Run Flat Tires
2003 318i SE Touring - Advice
Hi Enthusiasts! I'm the third owner of a 2003 BMW 318i SE Touring Car, 110,000 miles, that I bought from used approved Peter Vardy in Edinburgh in 2010. I've absolutely loved it! But it's coming to the end of its life, I fear. In particular the offside rear bracket holding the brake hose has completely corroded, so the garage (BM Motorworks in Stockport) has had to 'improvise' to attach it to get it through the MOT. There's some paint 'bubbling' over the wheel arches and general oil leaks - the usual for a car of that age. But it just got through it's MOT for another year, although with a load of advisories. I think it has a full service record - I got the inspections done at BM-Tec in Salford, and then last one at BM Motorworks last year. It's still a great drive, the interior is in great condition and all the electrics (apart from CDP) work great. So it pains me to let it go. But I don't have much mechanical knowledge and I think it's getting to the stage where, if it keeps going, it needs someone who can give it some TLC. I want a car I don't need to worry about. So I'm writing to ask if there's a forum where enthusiasts might be interested in buying it, someone who knows what they are getting into with one of these great cars? Any advice welcome! Thanks, Max -
8
X1 brake failure
Many thanks Dave it’s a minefield isn’t it! the calliper and ABS issue was sorted by a family friend who used to be a main dealer Service Manager, now gone independent. Paul - please do let us know how your daughter’s situation gets resolved? -
8
X1 brake failure
Morning Nellie and Paul As far as I was aware and have read the issue is with the ABS unit or to be accurate 2 ABS units (ATE MK100 and ATE MK 25A) that were fitted to quite a few models (not just BMW) between 2011 and 2020 and shows more often on cars with DSC. The big problem is the rate of failures compared to the number of cars with the unit fitted is small so BMW avoid recall on safety grounds, plus it seems (as far as I know) to only seems to happen outside warranty ie. over 3 years old leaving repair cost with the Owner. BMW will also argue that a car serviced by their Dealerships would pick up the fault at Brake Service and advise repair. Always expensive as BMW will replace units not repair them. BMW will also wash their hands if a repair or service is carried out by a Non Franchised Garage (But they are not alone here just about all Main Dealers and Manufacturers are the same) That doesn't mean all is lost there are a few Repair Specialists in the UK who repair (and improve) these units one I have used is ECU Testing who are very good. Now the calliper sticking? is the the ABS pump not releasing all pressure after braking or a fault with the calliper its self? it needs checking with a BMW capable Diagnostic system which would identify if it was a calliper failing/sticking or ABS issue. Also it is good engineering practice if a calliper sticks to either service both callipers or replace both If replacing Fluid only use BMW Spec fluid. It is sad to read tales of woe like this as generally the X1 is a good car and there is nothing wrong with Independent Garages other than some do not have the specialist knowledge or equipment If you are not able to DIY then I would find a BMW Specialist close by I am not a BMW garage just an enthusiastic car owner who loves to service and maintain my own cars plus some friends and families. Over the years I have amassed a strong collection of tools and knowledge including Diagnostics which allows me to work at Dealer level on several makes (Volvo, Mercedes, Audi, and BMW) Dave -
8
X1 brake failure
Hi Paul BMW insisted that as the brake fluid was touched by the independent garage who did the 45,000 service, then it was not a BMW problem. BMW eventually changed the brake fluid and retested, and NFF. Daughter had to suck up those costs plus the repairs to get her car back. Update: probably unrelated, but worth noting. coming back from the Lake District in the rain (June 2025), the O/S rear brake seized. Car was recovered back to Reading. Independent garage replaced calliper and pads, then ABS system, as they discovered a known fault with these brakes in that the ABS senses when the wipers are working and applies slight brake pressure to clear any potential water from the brakes . . . . -
8
X1 brake failure
Hi Nellie, My name is Paul and this exact thing just happened to my daughter in her 2018 X1. Would love to learn more about what you found out. Thanks, Paul
