Won't Start
dodgym3
Hi
Bought a bmw 635 csi that had been stood for 2 months it is MOT'd for 10 months. Put a new battery on her, drained old fuel and put fresh in but it will not start. Has great spark on all 6 plugs l, pump working as should, fuel on all 6, dried plugs and put oil in pots to create compression but it will not start.
Any ideas will be greatly received
Cheers
Tim
If all you have said is true then it will be a sensor(s) at fault.
Does it even "try" to start or just turn over? Does the Starter Motor spin well or does it seem tired?
Try unplugging and re-plugging all wiring connectors under the bonnet, maybe spray with WD40...
Concentrate on the Crank PS, Camshaft PS and Throttle PS, these three sensors are the babies that run the bugger via ECU !
Another thing to check is Fuel Pressure and its regulator, on the fuel rail(s) there should be, what looks like, a tyre-valve... press the needle in to expel air !
Just a couple of thoughts for you matey ;)
Like above, check the 3 sensors Dabsy mentioned first mate.
There are way to test them without getting new ones, but google it as I dont want the blame if you short something out.
Good luck
  • 2 years later...
My 635 has been running slightly lumpy, then just stopped whilst ticking over...now just spins over and will not fire .....put 3 gallons of fresh fuel ...but just spins ...any ideas please...
    2. 14
    3. 14
    • MikeDT earned a badge
    • Sdspeed went up a rank
    • Sdspeed earned a badge
    • Kiernan earned a badge
    • phil angel earned a badge
