E46 Speedo, Fuel Gauge, Abs And Traction Control Not Working
narbar
Hi as stated above I have all the problems which all occured at once on a very cold and snowy day. I was wondering if you guys had any idea what my problem could be with my 2003 330ci? Running perfect but warning lights everywhere! Thanks Dean
Reset the codes on OBD as Gav says, the fuses too inc. under-bonnet relays etc...
Seems like an electrical issue obviously but did you experience any interior condensation??
  • 11 months later...
Guest Mr.Beemer
I am assuming the speed sensor contacts are on the dirty side -
also go through the fuses making sure there sitting in properly.
first thing to do is to pull the codes through the obd port
      Electrical issues
      Wireless charging?
    • X5electrics earned a badge
    • Astonred earned a badge
    • Daz9048 earned a badge
