Hi all need a bit of advice ...
The e65 7 series has a annoying judder it feels a bit like a misfire or petrol shortage ..
Some times pulling away from a roundabout it sort if holds back before pulling away and when your doing 30/40 mph the revs jump up and down like its struggling
Start with a good clean of the throttle-body mate. Get it off and scrub it with some diesel
Failing that, if it's a sensor fault it should be stored as a code so run an OBD reader on it. I have one so if your at the Milton Keynes meet....
Thanks Daz for your input someone else said it may be a sensor prob won't make the MK meet for one this weather has put me behind at work and the engine fault drive moderately light has come on a couple of times this week I want to get it sorted before I take it on a 300 mile round trip
As above, dodgy injector(s) ? ...check fuel pressure too ;)
shame you won't be at the meet bud, would be GREAT to see the NEW bus!
Get ya hands on a cheap OBD reader though ^_^
Daz
What do you think of the fuel cleaner additives you can add to the tank could this help
Hit n miss with me. There's no proof it does anything.
Petrol, Isopropyl, carb-cleaner etc... Don't touch the element though ;)
Ok guys just an update in the judder ...
Although the air flow issue did solve the main judder once this was fixed it developed into a miss fire and engine fault light coming on with message saying
Excessive acceleration may damage catalyst.
The BMW reader showed that cylinder 7 coil pack was down so £87 later new one fitted and my faith in the V8 cruse ship was restored :-)
      X1 brake failure
      Engine misfire
      Engine misfire
      Engine misfire
    5. 11
    • Nellie earned a badge
    • PJH earned a badge
    • goffieman earned a badge
