Hi Paul.
Don’t get me started with bmw glue and headlights!
we used to drill a little hole in the rear of the units to allow a little airflow to remove condensation. Not sure if your units are factory sealed?
if you can get the lens off, then sealing them with silicone is easy. … getting the nuclear grade sealant off is the hard bit.
Hi all, looking for advice on this matter. Just noticed this am that I have a condensation build up inside of the headlight unit on my E64. Have not noticed it before.
I am assuming I have to replace the entire unit or is there a way to just replace the lens part and seal it up. Neither can I see any cracks or dings in the lens that would allow water ingress, so Im a bit stumped.
Appreciate any advice.
Paul
Appreciate this is an old post. I’ve just inherited an ACE2.0 in a used car.
Unanle to connect to it, ACE support given up and dealer not interested.
Did you have any connectivity issues with iPhone?
Hi
just bought a used BMW, was pleased to see BMW dashcam fitted.
After days trying to reset and connect to it, mails from ACE support (now given up) and no joy from dealer (washed their hands of it… “separate part though as it doesn’t come as part of the manufacturers specification, its an extra fitting and we don’t service them or give a warranty with them when they are already fitted in used cars”… I’m now rather stuck.
Anyone out there had similar experience or know of any guru that can help me?
Being an electronic engineer and working for a software company, thought this might be within my ability… apparently not.
Cheers
Paul
