My Ebay Problem
Morning JC That's better information A neighbour has i-Carsoft if he is around later today I will have a look At least you now know the cause, will your Maxi unit allow registration ? Dave -
17
I used another ODB reader, I am able to get additional information about the error code. It looks like the used RDC is not properly reprogrammed to work with my car. Do you know if the I-Carsoft 3 or Foxwell 510 is able to reprogram the RDC properly and resolves the errors? Or if the BMW INPA/ISTA the only tool that can fix it? Thanks! -
2011 X3 radio reset
Hi mate, thanks for the reply. If I disconnect the battery will I lose all of my settings? cheers. -
17
Thank you Greydog. I will be looking into these units! -
Pure oil in coolant tank
Morning Simon Welcome to the Forum If there is that much oil in the Header Tank it follows that water should be in the sump what is the Dip stick showing I have never seen anything like that before ? by the stains around the top of the header tank it almost looks like it has been poured in there? I have read of unscrupulous buyers distracting owners and pouring oil into header tanks then claiming head gasket failure and offering stupid low price to complete the sale. But thats OTT I doubt the engine would be running well if that much oil is being lost to the cooling system. First I would carry out an oil change if there is water in the oil then you will see it around the oil cap as a creamy residue and definitely in the drained oil. If the drained oil is OK and the Oil Filler Cap clean next step is drain the coolant remove the header and clean it (if possible) with the coolant drained you should be able to check the oil cooler and its seals to the rad Good luck detecting the cause Dave
