Im looking into possibilty of running my 3 series coupe with a t5 engine from the volvo 850 t5.My first hurdle is knowing what gearbox the p reg coupe uses and is it hydrolic or cable? secondly is the speedo in the gearbox electronic or mechanical also what size clutch do they use is it a 220mm or 240?,
Hydraulic,speedo sensor on the wheels,clutch is engine dependant!
What do you mean clutch is engine dependant? the speedo sensor is not connected to the abs is it or is it seperate?
Go on real oem with ya chassis numbers and it will tell what clutch is on it.but what engine is in at present? Yes works off the abs.
I have the 1.9 m44 i think its called
My plan is to swap the bemmer bell housing for the volvo bell housing and have the volvo flywheel restuded to fit the bemmer clutch
      EXTERIOR MIRRORS AND CAR WASHES
      cruise control switches
      My old e36
      My old e36
    5. 3
    • Baker25X3 earned a badge
    • Ian old e36 earned a badge
    • snake2202 earned a badge
    • stehay123 earned a badge
    • Professor80 earned a badge
