Engine Management Light Help
suspension / service
morning, here again after bit of investigation shocks, arms,springs ok ,but got constant thud coming from passenger front footwell now I'm startingto feel it around drivers feet 20mph ,iknow it's not wheel balance because comes in at such low speeds ,what do we think cheers jerry -
Profile setting
Hi Steve As the car is still under warranty why not get the Dealer to sort it ? It may be simple "a learning process for you and the car" or possibly a software upgrade ? Dave -
Profile setting
I have 2025 X3 I have created a profile for myself and then I set up another profile as ‘driver2’ when I use my key it picks up my profile but does not show my 2nd profile I have tried to set it up again but it shows on the screen as driver 2 is already set up but I cannot find the profile anywhere any help is much appreciated -
X3 Door locks
Thanks for the reply. It's passenger and rear doors and tailgate, but only occasionally. I'll look at a replacement actuator and see if that solves the issue. 👍 -
X3 Door locks
Welcome Paul. is it all the doors stay locked at the same time or a random one? my Porsche’s rear right started doing it and it turned out to be the door actuator. if it’s all at the same time every time, I would look at the relays as it’s giving a signal to all doors. Random 1 door will be getting the signal but failing to actuate
