Battery Keeps Dying
all blacked out
Hi guys,
the battery in my car keeps dying I chargr it up or jump it then drive it for awhile and works fine but then when I turn I off it will most of the time not start back up like the battery is dead so I replaced the battery but it started doing it again any ideas would be great thanks!
Have you got a multi meter? If so charge the battery over night. Start the car up and put your multi meter on + and – and see if you are getting 13v+, any less than that and you have a charging problem.
Does it run and drive 100% once jump started? If so and it is charging the battery it could be a battery drain, test to see if it is charging then come back to me
