Fan Control
scoand
Do the vent buttons on the heater-control not work then? (Above the "Auto" button on most BMW's)
I assume you are referring to the recirc button. Yes, everything works except.I can't manually control the fan speed.
the climate controls do have a mind of their own im afraid .......... does the unit go on and off occasionally too or has it not got to that stage yet?????? there is a resistor inside that tends to go and can cause different problems with the climate control..........
Doesn't go on and off by itself.
heater resistor pack "hedgehog" will sort that out.
"Probably" will, but needs to eliminate others first... It is a common fault though !!
His 2002 model will have the updated resistor but just about anything can fail ;)
