X5 3.0 2004 Diesel P09F6 Fault Code ... Help :(
Lower window molding
Morning Shawn Take a look at www.realoem.com put the last 7 digits of your Vin into the search box, it will call up your model then search the Body and Trim sections You should find what you need there, once you have the part and it's part number then you can search for the best price for a replacement Dave -
Can you guys tell me the best place to order a lower window cowl molding for a 2013 BMW 320i? Mine is super dry rotted and I’m getting water in my driver’s side floor board. I checked the sunroof water tubes and they seem to work well. I also ran water on the outside of drivers door to see if it was the door vapor barrier but didn’t notice anything out of the ordinary. The cowl is the only obvious thing that looks bad. -
Electrical issues
Anyone having major issues with their PHEV x5 SME issues causing major faults BMW say all is good be interested to know if this is a one off or a major manufacturer issue -
Hi Paul Carpets are a "Touch and Feel" purchase in my mind for my wife's Subaru I had a local Carpet fitter make up a set. He did a great job all edges taped and stitched and the non slip pads on the back he was able to get the car mats out of off cuts (Contract quality Wilton in Beige). He charged around half the cost of Subaru direct might be worth tracking down a fitter and asking Another thought are Guys like Quarry Motors but again you would be buying unseen but at least they know what OEM BMW mats are. Dave -
Can anyone advise on best place to obtain new full pile replacement mats for my E64. Just had a bad experience on ebay so they are going back, totally missold. Just need a nice set in black with the velcro pads already fitted as per BMW spec.
