Count To 5000
Damper pulley
Just told today that damper pulley is cracked !! Wondered how critical/,urgent this might be as ideally needed to use car tmrw ?? TA -
4x4 abs ebv dsc failure
So guys back again ive got a fault code on my bmw x5 e70 saying 4x4 abs ebv failure previous owner just went and changed the abs pump but never coded it so I sent the original off to ecu testing to see if it was faulty it came back today and they said the original pump had no faults at all but whilst I was waiting for it to come back the car has been doing stupid things like wipers staying on when car turned off passenger window not working to the point the motor burns out on it radio staying on when cars off im literally getting to the point i give up only owned it a month any help I would appreciate it -
X3 - YOM 2013 -Coolant change
I would like to change the coolant on my X3 but have never seen hose clips of the type fitted as it looks like complete ring. Any ideas on removal and tips on bleeding the system would be appreciated. Thanks -
5
Morning Frank Welcome to the Forum Rear Suspension not right ! Isn't much to help diagnose your problem so (1) is the system loosing pressure overnight ? (2) Is the compressor running (you should hear it under the back of the car) ? What dash warnings are you seeing ? Genuine air bags are around £80 each A replacement compressor £130 A Control unit (second user) £50 then there are 2 ride height sensors £25 a pair 2 fuses and a relay. So the system isn't complicated and can replaced completely for around £350 to £400, most common issues I have seen are leaks. If the system is loosing air the compressor ends up over running and either timing out (dash warning) or wearing out and while it will run it just can't produce enough pressure. My guess is, that if the previous owner changed the air bags the compressor is possibly on it's way out, easy to change a real plug and play job. Hope this helps Dave -
5
new to this so not sure if this is correct 'place ' i have a 2013 520 estate ,rear suspension not right !! seems airbags were replaced by previous owner ...mechanic says module has been disconnected at some stage previous ... he hasnt repaired one before but is willing to remove it/try fix it but of course cannot be sure ..am told they are quite expensive though if need be bought ...also see some people replace air one with conventional shocks/springs ...really lost on all of this as to best/easiest,,,, least expensive solution ... thanking ye in advance !!
