I don't understand your question but the Alpina rims look sweet B)
@ this time I will imagine that your box is fully manual...
Your motor is the M52 (same as mine), there is NO short-shift facility !
If you need short-shift then you can either, reduce the length of the gear shift (inside the car), or, shorten the selector-actuator on the side of the gearbox !!!
HTH
is it true for the 328 e36 a z3 gear stick works as a short shift?
I'm conf000sed. How can they 'work' as short shift? surly its short shift or it isnt
I'm with daz on this one!
i have no clue its just what one of my mates sead. they are probly talking bubbles.
      Fault codes 130716/P1523/p13c9
      Reverse camera
    5. 3
    • Germaine earned a badge
    • Davross earned a badge
    • kyzote went up a rank
    • Meggy earned a badge
