E46 323 Problem
sean
hi all my bmw does not start got a mechanic in and he said that there is a signal going to the ecu to fire but none coming out from the ecu is this just a new ecu repair or is there further problems many thanks
To replace the ECU has its own problems in that it has to be matched to the car by the stealer !
Could be a relay fault under the bonnet... Does the starter turn the engine?
hi yes sorry aint been on for a while been awqy with work its red
the car does turn over when attempting to start but not much else
will a new ecu with same codes just bolt on and go or will i have to do somthing else to it
many thanks all for your help
      M buttons
    5. 4
      Just purchased 320d Touring
    • Jeff1965 earned a badge
    • Eagle2562 earned a badge
    • Bmw5 earned a badge
