Rear Brake Pipe
kevg72
Hi Guys, ive got a rear brake pipe (drivers side) that is corroded alittle and been advised to change before next m.o.t (next year)! Just wanted to know does it join to the other side (passenger side) as one pipe or does it split in middle so only drivers side need to replace?? Any info will be good. :)
They are devided mate... They have to be this way due to ABS, etc...
Use kunifer (Long life) piping, and goodrich hoses if you can afford it...
Just to add mate, If you only had an "Advisory" on your brake pipes they are not leaking, they can only fail the pipe if it leaks these days.
My advice is to coat the pipes front to back in copper grease (after getting shot of the muck etc) DON'T use a wire brush...
HTH
