Looks
G31 Oil change
Hi, I have recently bought a 2020 520d Touring G31 and I want to do an oil and filter change. I have not this on a car before, I know it’s pretty simple, but just wondered if there were any YouTube sources that you’d recommend please? Also which is the best oil to use? I want to save some money on labour and start to do some jobs myself but want to select the best products. I have had a bit of a look online but not sure if the sources I have found are recommended within the community. Thanks in advance for any pointers 🙂 -
DPF fAULT CODE
Hi Dave Thanks for that. I am going to spend a bit more time on it just to get to the bottom of it all. I hve been quoted 420 Euros to remove and ultrasonically clean the dpf, but I am going to hold fire -
New owner looking for some advice please
Morning James. first try quarry motors in Sheffield. They are really helpful. -
DPF fAULT CODE
Hi Stewart I thought the Foxwell would be capable If you have no warnings or faults showing i wouldn't be concerned as you can trigger a DPF Regeneration cycle whenever you wish (only really needed if all you are doing is lots of short journeys) my E70 I trigger around twice a year. No worry about the MOT and DPF as it will be the original, it's just the cars ECU that thinks it is new. Dave
