Z4 Coupe Aux not detected on Business CD system
Hi all,
New owners here.
We just bought ourselves a lovely Z4 Coupe (2007) and had a great fun driving it home. No issues with it apart from the Aux input is not being detected on the stereo.
I’ve read it could be a connector issue or a coding issue. How do I go about working out which one it is and how easy is it to get fixed? Is this something I can fix myself without too much faff or is this something I need to pay someone to fix?
Any help much appreciated!
Hi Lewis
From what I understand there is a CD Changer input and an Aux Input on the back of the head unit if the Aux cable is plugged into the wrong one it doesn't register. If the Aux port was fitted by someone else (not BMW) that is quite possibly the problem. You will need to remove the radio to check, at the back of the radio there is the main power/speaker connector on the left hand side the Aux connector should slot into the main connector. Beneath the main connector is separate connector socket for the CD Changer.
So pop out the air vent unit above the radio (2 flat screwdrivers and a trim tool) undo the 2 screws that hold the radio in place and slide it out there should be just enough cable slack to see what is plugged in to where. If the main power/speaker connector has a small plug beneath it disconnect them both and at the bottom of the main power connector you should see a slot to take the Aux connector push it home until it clicks replace the power connector and antenna if you unplugged it and slide the radio back. Turn on the power and now you should have a working Aux port. Put the screws in and slide the air vents home 15 minutes work 😅
Hope it works for you
