Having a problem with my airbag light flashing on and off, iv bought one of them bypass units you can buy but before wiring that in how hard is it to just remove the bulb?
I've never done this on a BMW, but had imense amount of hassel with ABS on my Tigra..
Ended up removing the bulb for MOT...wasn't that difficult, but i don't know for sure how to take bm dash apart
whats this bypass unit you have brought, have you got a link to a page so i can see it??
I dont like it...as an auto leccy my self..
But if you having probs fitting it, ill do it for you before the meet
Yeh I don't like it to tbh that's why I asked how hard it would be to take speedo out to remove bulb, and ok thanks bud
I think this is a safety issue and should not be taken lightly...
The most common fault is the drivers or passenger seat pad sensor, have a fiddle at the wiring under each seat to see if the light goes out...
Personally I wouldn't remove the bulb.
I would use the bypass mod only for MOT or if I were selling it...
Just my thoughts guys ;)
not sure if im correct here, but i think if you stick some tape over were the light is for the mot they cant remove it, its a visual check.
i may be completly wrong there though :unsure:
You could stick a small "M" emblem over it to make it look natural !!!!
thats a good idea :lol:
Not as Soft (Daft) as I look eh?
I know it's a fault with the senor and I cba to wire that bypass senor in so would rather take bulb out for now
Yes well chufed with that, only took 10 mins take the passenger sit out cut a couple of wires and then wire in the bypass and presto... Done lol
    2. 17
      2011 X3 radio reset
    4. 17
      Pure oil in coolant tank
    • StaffordSteve earned a badge
    • ndsim earned a badge
    • Ken C earned a badge
    • stehay123 earned a badge
      Collaborator
