Sound amplifier
I’ve just discovered that water leaking in to the rear boot left side is a common problem, I don’t know how the water gets in but my sound amplifier was in about 3 inches of water.
Does anyone know if the amp can be fixed or replaced with an aftermarket amp or is it a case of having to buy another bmw amp
Thanks
Hi James
You could try companies such as ECU Testing or Cartronix another alternative may be get the Part number and search Dismantlers like Quarry Motors
Before replacing it though some Talc puffed along and around the boot seals then a wash may give clues to where it is getting in, but more important check the boot floor seal/drain is not blocked. If you have a sun roof make sure the drains are clear
Good Luck
