Bmw 1 Series 1st Gear select Problem
Hi All hope your well
So he we go I have a Bmw 1 series I currently having some issues with first gear it will goes in when stationary. The min I try to pull forward it jumps out of gear. So my thought was it was the slave cylinder how ever I went to my local parts store and he questioned if it was that . Which then made we question it. the only other systems are the clutch pedal doesn't always retract to high and there is some build near the gear rode "sorry no it's not call that" but unsure what its called everything works fine apart from that no noise from gear box . I have read on the internet that it could just need a fuild change is this a possibility or I am looking something more expensive ? please help I am going mad
Morning Rick
By the description you give it would seem that the gearbox is ready for a full service and while it's out new clutch
The poor old Gearbox is often the most abused part of the car Engine gets regular oil and filter changes while the gearbox is often never touched until it breaks
Good Luck
to be fare within all my years of driving I don't think I have ever change a gearbox filter
Morning Rick
Your transmission is made by ZF a check of their website should let you know what their recommended service intervals are from memory 60k to 100k dependent on use and climate. I have read that you can also get a shift control service kit
Don't buy cheap get ZF stuff check out www.realoem.com put the last 7 digits of your Vin into the search box it should bring up your model then check the Gearbox section get the part numbers you need the use the Internet for best prices
Good luck
I have just had mine serviced, as when I bought it the box was buttery smooth. I could, lately just feel a bit of a change on the change down. As it was 6 years old and 50k miles decided to get it done and now back to buttery smooth. The old oil definately needed changing. There is also a filter in the gearbox, so surely that needs changing at some point.
BMW say its lifetime, but will offer a service on it for about £1500. ZF say 6 yrs/60k miles. So I went to my local indie and had it done for £415.
I guess it depends how the car is driven light or lead footed and motorway or town, and in some small measure luck of the draw.
Theme by IPSFocus
Bimmer Owners Club Powered by Invision Community
