Connect Phone Via Blue Tooth
G4VHD
  • 2 months later...
wat make is your head unit??? i had same prob on sony xplod i found a user gide on line... i had to turn on blue tooth on my phone and then hold down the bt button on my head unit for 6 sec till it flashed then search for devise on phone enter 0000 and all was good.....
hope that helps good luck
  • 6 months later...
Hi all,
I was reading through old posts on this topic regarding paring iPhones with Bluetooth. I'm having a nightmare getting this activated. I've done all the procedure required and when I pick up the BMW BT request I click on join and type in my passkey, however its not allowing me to join, I have removed all the old users and according to one of the posts you need to use 6 digits for the iphone passkey which I done and still no joy. Fecking nightmare! Any advice to offer??
L
  • 1 year later...
2006 325xi.....can pair Moto Photon Q phone to car, works well, but can't get the car to accept the !@#$% Phone Book from the cell phone. Any one have any (clean, viable) recommendations re: how to fix this issue?
The web has a ton of blogs on this topic but with a couple hundred "solutions". After trying the first 20 or so, I gave up.
HELP MISTER WIZARD!!!
Enter the phone function on the car and set it to search.
Turn the phone bluetooth on and search as well.
When they find each other, one will ask you to enter a code - just make one up 1234 will do.
Enter the same code on the other device.
Bob should be your uncle.
Without looking at the car I can't remember the exact menu options but, that's pretty much how it works!
  • 2 months later...
  • 2 months later...
      M buttons
      Steering wheel replacement
      F30 A-pillar install
    • amebb went up a rank
    • Conmil earned a badge
    • Loulou earned a badge
