Ill give £20 to the last person to post on this thread
Knocking noise top of engine.
Hi, I have this knocking noise on the top of the engine. It started with a low knocking sound then it got progressively worse until I stopped and got recovered. New top turbo 3k miles ago and fresh oil change. Car seems to be all working fine apart from the aggressive knocking. Any ideas? 2013 x5 40d 110k on the clock. IMG_6024.mov -
7
Loud knocking noise front top end and smoke
Hi, I have the same fault, was it the injectors? -
Electrical issues
You haven't given much away here ? But Welcome to the Forum anyway I know there have been a number of recalls since 2020, here I am assuming (dangerous) that all yours are up to date ? I have read of several incidents of SME faults 21F21F seems one of the most common with PHEV. Why BMW seem to deny there are issues I just don't understand. Check the US sites they may have more information due to Class Actions in the USA manufacturers tend to move faster with fixes and Recalls Good Luck Dave -
Lower window molding
Morning Shawn Take a look at www.realoem.com put the last 7 digits of your Vin into the search box, it will call up your model then search the Body and Trim sections You should find what you need there, once you have the part and it's part number then you can search for the best price for a replacement Dave -
Can you guys tell me the best place to order a lower window cowl molding for a 2013 BMW 320i? Mine is super dry rotted and I’m getting water in my driver’s side floor board. I checked the sunroof water tubes and they seem to work well. I also ran water on the outside of drivers door to see if it was the door vapor barrier but didn’t notice anything out of the ordinary. The cowl is the only obvious thing that looks bad.
