Ill give £20 to the last person to post on this thread
DPF fAULT CODE
Hi Stewart I thought the Foxwell would be capable If you have no warnings or faults showing i wouldn't be concerned as you can trigger a DPF Regeneration cycle whenever you wish (only really needed if all you are doing is lots of short journeys) my E70 I trigger around twice a year. No worry about the MOT and DPF as it will be the original, it's just the cars ECU that thinks it is new. Dave -
New owner looking for some advice please
Hi all, I have just purchased my first BMW, a 2020 520d Touring M-Sport. I have spotted a few bits that need replacing: - Door seal at bottom of drivers door - Plastic cover for the vent just behind offside front wheel - Lower part of one of the wing mirror cases - The interior plastic covers on either side of the rear window (on the main body of the car, not the tailgate itself). What sites would you recommend for me to try and find secondhand spares please? Obviously for the wing mirror case I might need to order that from BMW as might not be as easy to get the right colour second hand. Any input greatly welcomed, Thanks James. -
5
DPF fAULT CODE
Hi Dave, It has the ability to regenerate and tell the ECU that a new Dpf has been fitted. I live in Spain and the diy car scene is non existent because a car has to be totally original to pass the mot to the point that I had to produce the original documents to confirm the electric tow bar was fitted at the factory. -
5
DPF fAULT CODE
Morning Stewart Even if the Foxwell can't give soot and ash levels it should be able to tell the car it has a new DPF Dave -
15
Fuel rail pressure problems.
Morning Tony Welcome to the Forum Fuel Pump Relay is one of the first suspects, then Crank Sensor and Cam Sensors Did the injectors go back in the correct order? I take it you have a Diagnostic scanner? if the injectors were mixed up you will need the numbers from the top of each injector and they will need registering to each position. Hope this helps not hinders Dave
