New member
Thanks very much for welcome, I've done the history search via BMW dealer and there's none there! As the one previous owner was a sales manager for a large franchise, I'm thinking they did the servicing but maybe didn't have access to the BMW system to update it. I'm getting it serviced at main dealer next month and that will allow me to purchase a warranty from BMW or possibly elsewhere as BMW warranty dept pretty useless so far. Just back from 3 days in Yorkshire and it is an amazing car to drive for sure! Cheers Dave -
2016 M240 "lumpiness" at steady low speed
Thanks Dave, it's just noticeable at that lower steady speed, higher steady speeds it doesn't seem t happen, there is an occasional hesitancy to accelerate when 'floored' mind. Think the scan step is required! -
645ci coolant
Morning Rob 1st The temperature sender in the water pump housing is dual purpose it sends a signal to the DME which interprets that for both Oil Temp and Water Temp I would change it when changing the Thermostat If the Aux Water Pump isn't recirculating coolant, (1) is the Coolant level correct (2) You can hear the Aux Pump running but it doesn't seem to be moving coolant so check the Coolant valve on the nearside inner wing (not uncommon for these o fail) Is the noise the Vacuum pump (constant) or the Emissions air pump stops after a short while? If all sensors are operating as they should there could be a problem with the cluster it is better to repair the original if you can there are a few companies who do it ECU Testing or Cartronix come to mind. Good luck Dave -
Morning Kev Welcome to the Forum If you drop down a gear or two to increase revs what happens? When was the car last serviced ? A misfire could be Coil Pack failing Plug failing a vacuum or air leak on the inlet, I would start with a diagnostic scan and go from there. Dave -
New member
Morning Dave Welcome to the Forum Very pretty You should find the service history in the iDrive/Connected Drive or a good BMW Dealer should be able to help (they may well charge) They will need proof of ownership and your Vin With your car only covering 27k and extended service intervals now common place it may be it has only had it's PDI As for Warranty talk to BMW service if your car has a BMW history they should offer an extended warranty (not cheap but comprehensive) If they can't help then search the open market. ENJOY your Beemer Dave
