Toyos?
Hey has anyone ever run with toyo proxes t1r tyres on theyr BMW?? If so how are they? Thanks
ive never used toyos but i do no a little about that tyre in question thru friends having them
if i remember right, very nice 'sticky' tyre in both dry and wet conditions with a good average life. highly recommended although cant comment on them for bmws
Ok cheers guys, I need to do note research I think, I've heard mixed things about them!
blackcircles.com usually have an awesome price on toyo parada's theyre AWESOME tyres
Hi, Ive got proxes st fitted to my x5. Excellent tyres good grip in all weather conditions never got stuck in all that snow.
Hi, Ive got proxes st fitted to my x5 never got stuck in all that snow.
you drive an X5 of course you didn't! lol
Not bad for size: fronts 255/45/19 £125.00 each Rears 285/45/19 £130.00 each.
was expecting at least double that!!
From Jefferies Tyres in Bromsgrove Westmidlands 01527831829.
Look online you can get tyres sent to your home or direct to a fitter in your area for good prices. All the big fitters like Kwik Fit rip you off
when they know what car its for.
  • 1 year later...
hankooks aint bad,good price good grip,unless you is an F1 driver
  • 4 weeks later...
maxim / federal are good tyres mid range budget but v good
the tread wear raitin on the side of the tyre tells u how good the tyre is the higher it is the longer / harder it is ie anything over 280 is long lasting and harder compound anything below is grippier but wont last long
i learned this from the maxis rep when i used to fit tyres at the taxi company where i used to work when we moaned that a set of tyres only lasted 4000 miles we had a set with a 200 rateing
  • 2 years later...
Had proxes on my toyota supra, they were ok but not a patch on bridgestone potenza re050, of course it all depends what you want from a tyre.
  • 3 years later...
I've seen several types of tires under Toyo proxes such as R888, R1R and more. Which is the best one to use so far? Hoping to get some recommendations or comparison for those tires.
