Keep real BMW owners helping real BMW owners, while we work towards motoring savings.
door switches
Have a 2013 520 estate ..F11 i believe model is ...having issue with passenger door lock .. when you use fob or button on dash to open it the button in/on the door pops up and down several times but always returns to locked position !! also can now only open tailgate by using (white) button in car on drivers door post as door catch on tailgate wont open it anymore ... lastly(honest😉) when tailgate opens it only goes up about halfway which im assuming means struts need repairing???? or replacing ... ANY help/advice re how to repair and/or best place get replacement parts (im in Dublin ) would be very much appreciated
TA
Morning Frank
Check www.realoem.com put the last 7 digits of your Vin into the search box it will call up your model, then search the sections for the door actuator and boot/tailgate struts note the part numbers. Then search the internet for the best prices.
Changing the boot struts is straight forward with the help of a trusty broom to hold up the tailgate remove some trim to expose the electrical connector and remove them. Changing the door actuator is again a straight forward but the door panel has to be removed take care with the inner membrane don't damage it. A hair dryer or heat gun will help soften the adhesive that holds it in place.
I believe there are a few "How Too's" on the internet
Hope this helps
THANKING you Dave will have look at that ... MUCH appreciate your reply and clear practical advice
  • 3 months later...
me again so apologies !!! issue with passenger door lock still not sorted as mechanic i use very reluctant to take it on and its become more frequent since that when you use fob or button on dash to open door/s ...one on pssenger door just pops up and down repeatedly and rapidly but always finishes doing so in locked position ...i,e button down ... iv looked through https://www.realoem.com/bmw/en/showparts?id=MX12-EUR-02-2013-F11-BMW-520d&diagId=51_7830 this to see what part is needed but am none the wiser ...as always any advice on which part i need to get/order for this would be very much appreciated ..
Morning Frank
Sounds like the actuator is your issue not a difficult job but you do need the door open to remove the door card, then peel back the inner membrane (hairdryer or heat gun to help soften the adhesive) Also worth considering is the cable to the outer door handle I have had one stick on my own car
So first question can you get the door open???
Ta for that Dave yes i can get it to open eventually ...just have to keep pushing button until it stops in the open position ...not sure if link i (tried) put in last message works but trying figure which part or number in diagram is actuator that i can try source it , hopefully on the www as im in Dublin and main dealer bmw stuff here aint cheap
TA again .
TA for that Dave ...yes i can eventually get the door open ...guess issue is mostly about been sure of ordering the right part ..and from where ideally non main dealer or UK as customs etc has become a major p.i.t.a and expense here (Dublin) since brexit stuff has taken hold !!!
TA again
should have said one reasons for uncertainty is because when i look for part on the www under that heading i see it listed for anywhere from 29 euro to 400 plus euro !!!!!!!!!!
Morning Frank
Many BMW Dealer Parts Counters have Ebay/Amazon accounts that will explain the high end costs 😅 others are often copies but if they come with a Warranty fit and work I have no issue with them. Some may be second user parts there is a thriving market for recycled BMW parts should be lower end (but don't hold your breath 🤣)
Good Luck
  • 4 weeks later...
THANKING you a Dave for that ..as happens i since left car with a recommened garage re various issues pre nct(your mot)...too long a story to bore you with but after all the pre caution work and possible fail issues worries only thing highlighted was a leaking rear shock absorber... so could i ask if you know do all f11 (&f10 ?) model estates have same type or fitting shocks ...as again i looked on the www and prices seem vary from approx 80 pr each up to hundreds ...last question ...is replacing them something someone of limited (me!!) mechancial ability could manage allowing i have axle stands/trolley jack and reasonably stocked tool box ???
THANKING you again
Morning Frank
The big difference in cost would only be if your car has the electronic dampers (VDC) or standard easy to tell just jack up the car and take off the rear wheel if the shock absorber has a box on the side with a cable coming out lucky you you have the expensive one 😂 If it is a plain shock then your OK check www.realoem.com for the correct part number then search the internet for the best price . The bottom bolt is always really tight 14mm top nut inside the boot hidden behind trim should be 12mm but changing the shocks is a straightforward job well within the average DIY home mechanic
Hope this helps
