Rear Windshield washer nozzle missing/ issues in 2021 X2
Hello fellow X2/X1 owners,
I’m hoping someone can shed some light on an issue I’ve been having with the rear window washer. The sprayer located behind the third brake light (in the trim above the rear window) hasn’t been working properly since I bought my X2 over a year ago. Early on, it would continue leaking water even after I turned it off but then eventually stopped.
Now it appears the nozzle may have come loose and fallen inside the trim—I can’t see anything through the opening anymore. When I activate the rear sprayer, water just leaks along the trim instead.
At the same time, my front windshield washers have also stopped working correctly. They have very low pressure, spray briefly for a second, and then stop altogether. I can still hear the pump running when I activate either the front or rear washers. (For reference, I’m using proper BMW-approved washer fluid—not silicone-based.)
So at this point, I seem to have two issues:
  • Rear washer nozzle likely disconnected or hose loose inside trim
  • Front washers now have little to no pressure
The vehicle is still under CPO warranty, and I plan to bring it into the BMW dealer and hopefully have this repaired at no cost.
Has anyone experienced something similar or have any insight into what might be going on?
Thanks in advance,
Lew
BMW X2 F39 Heckscheiben-Reinigungssprühdüse 61687320256 7320256 NEU Original _ eBay.html
