2011 x5 rear suspension
Hi
My x5 2011 rear n/s air suspension hight lift sensor light is on all the time, it's 40 mil down ,I've changed the high lift sensor but it is still lit up on the dash and it's still 40 mil down
I've not heard the compressor come on , the other side is ok ,
Can anyone advise me please
John
Morning John
My first thoughts are leak in the air spring or a blown fuse check them all. When you say you changed the high lift sensor I assume (dangerous) that was the rear ride height sensor ?
If there is an air leak the compressor will run a lot and can be damaged, replacement is not a bad job and compressors are not bank busters (check the internet). I have seen several where faults were caused by faulty wiring at the Ride height sensor plug check carefully. It could be a Suspension Control unit (rare but not impossible) easy change plug and play
Hope this helps
Hi John
The Suspension Control Unit should be programmed with the correct ride height so once the fault is cleared things should return to normal Fuses are in the Front Fuse Panel No 32 Relay is R2 in the rear Fuse Panel No 107
Correct ride height should be 720mm +/- 5mm measured from the bottom of the wheel rim to the wheel arch lip through the wheel centre
I took the car to a man with a computer for bmw vehicles and the car is not communicating with his computer in the rear air suspension set up, all fuses and relays are ok
Any ideas anyone
Rgds
John
Morning John
It depends what Diagnostic he was using there are several systems that can communicate with the car but mainly the key control units. Foxwell, Autologic, iCarsoft there is quite a long list then there is BMW ISTA/INPA which can see every component, it includes Workshop Information (WIS) which gives Photos and descriptions of how to do the job plus advice on test programs to confirm diagnostics. I use ISTA at home
The air suspension system isn't complicated it has 2 Air Springs 2 Ride Height sensors 2 Fuses a Relay a Control Unit (Programable) and the Compressor.
As your issue started with the Rear Ride Height sensor I would begin there with the Plug Connector and wiring make sure there is no damage to the wiring. You will need a Wiring Diagram (ISTA) each plug has 3 wires that feed back to the Control Unit (the Control Unit is in the Rear Right Cubby at the bottom of the Fuse board) BMW rear air springs are used on several models not just X5's I have seen several where the wiring had become cracked and brittle with broken connections. That is where I would start, if continuity is there then in my experience Control Unit failure is rare but not impossible a replacement from a Dismantler would be a starting point and not to £££ they are plug and play. With ISTA they can be checked and recalibrated if needed.
It turned out to be some bad connections in the wiring and it now works as it should, thank you to all for taking the time to help
Rgds
John
